radiator flush procedures??
Old 01-09-2011, 02:09 PM
2fast4u1989's Avatar
Default radiator flush procedures??
hey i have a 95 lt1. i wana drain the radiator. my question is how do i drain the overflow tank? or does it all drain when i drain the radiator
Old 01-09-2011, 03:14 PM
96azz28's Avatar
It drains th whole thing
Ive replaced my radiator before
and when i flushed it the radiator was empty
96 z28-bolt ons:
Magnaflow exhaust,(no cats) LT Pacesetter headers, ORY,MSD ignition 6AL, stall converter 2800, and some suspension work.
Old 01-09-2011, 06:56 PM
~BuMps AloT~'s Avatar
I would just pull the overflow tank out, because this will allow you to flush it out a lot better then if it were still in the car.
To pull it out you will have to pull your battery out. Then there is a single 13 or 15mm bolt holding the tank in. Pull the tank out and unhook the hose that goes back to the radiator. This is very easy to do.
Quick Reply: radiator flush procedures??
