Brake Pedal Goes To Floor
i changed my master cylinder and still it goes to the floor. i bench bled it and bled at the calipers. i have no dash light on also. im guessing my problem could be the black box the 2 lines go into???? please help!!
OP have an assistant hold the pedal down while you crack the lines open indivudually on the master, then try bleeding the calipers again.
