simple question regarding: z06 pcv MOD
I've got the Z06 valley cover in place, and the Z06 coolant lines. There are 2 ports coming out of the pass. valve cover. I have these plugged - is that correct? Also, there is one big port in the back of the Driver-side valve cover (where the PCV line used to go). Does this need to be plugged, or should I just install a breather there?
I've done countless searches on several sites with no luck. Thanks for the help!
