need help ls1 in 1st gen camaro
has any one used this pan http://www.jegs.com/i/Moroso/710/20140/10002/-1.
also please help me with my swap parts list,i have seen that some mounts move motor to far foward or to far back to firewall.
I will be usning stock stock front frame, any help would be highly apprecaited.
plans are to use a lq4 with ls6 intake and f-bady fuel rails with corvette filter reg,and prob a external pump.any sugestions would be great too thank you kevin.
Watch the front of the pan to frame clearence, depending on the mounts. I used 20141 w/edelbrock mounts and it touched. mo biggie though a little shim and grind made it work.
