Rocker Arm
Old 01-14-2011, 01:40 PM
BTLD_LS1's Avatar
Default Rocker Arm
Im still running the stock 200K mile rockers on my car and its finally time to make a change.
Im looking at the Harland Sharp SLS17 - Harland Sharp Shaft Mount Roller Rockers and the COMP Cams 19024-16.
What has the experience been with both of these?
Im leaning towards the shaft mounts right now as the motor sees a lot of revs
THX
Old 01-14-2011, 01:54 PM
RARON455's Avatar
I have heard of some guys having fitment issues on the harlands,,I would definately go with the shaft mounts they give you stability. I just bought a set of the new yella terras 6645 they have the best rep and will hold what you may throw at them later on down the road. price is a lil over 400 shipped from one of our sponsors. BEST advice in the world when modding is buy the absolute best part you can afford, that way you wont have to buy the same part twice.
Old 01-14-2011, 01:55 PM
BTLD_LS1's Avatar
I forgot all about the yella terras 6645, thanks for bringing them up
Old 01-14-2011, 02:15 PM
brian_rs/ss's Avatar
ws6store.com has the best price i've found so far on the yella terra's. might want to check them out.
Old 01-14-2011, 02:36 PM
BTLD_LS1's Avatar
Thanks for the heads up, but jegs has them beat by $20
Old 01-14-2011, 03:08 PM
JPH
JPH's Avatar
A yella terra rockers would be a great addition to your setup imo. Stick with a 1.7 ratio, since you have plenty of lobe lift now.
Quick Reply: Rocker Arm
