Gears swaps on ctsv-Fbody t5-6
I want to swap 1st and 2nd gear between my two t56s. Is there going to be a compatibility issue between my fbody t56 and the ctsv t56 with these gears? thanks for any leads
scott
scott
You can't split gears between sets because of the single cluster countershaft. Also, the double/single cone synchros&gears of the Fbody are not compatible with the triple/double cones in the late model GM T56s. If you want, you can swap over the CTSv to a MM6 gearset from a C5 corvette, but all the ratios will be MM6. You'll also have to lose the dual-mass flywheel if you haven't already.
