Truck Injectors and ECU in LS1
the injectors/rails are not interchangeable since the truck ones are shorter and use a different connector on them. the ecm as-is will physically fit, but the program is off and there are a few wires that need to be repinned.
ecu
Ok, I can splice the LS1 connectors on the truck wires...no big deal.
Will I need a dynotune or just a Diablo tuner for the upgrade?
Which pins need to be changed?
