monster clutch weight info!
Old 01-17-2011, 01:04 PM
tdi_hatch's Avatar
Default monster clutch weight info!
i just wanted to put this info out there since i just weighed my stage 3 monster clutch with chromoly flywheel 18lb. This is for people later looking for weight specs.
my stock ls1 clutch/flywheel assembly 49 lbs
ls1 stock flywheel with spec stage 3 puck 50lbs
My monster clutch stage 3 with 18lb flywheel 46lbs complete
there you go guys
Old 01-17-2011, 01:28 PM
Chronicle's Avatar
Yeah, the stock T-56 flywheel is a heavy ****. I considered weighing everything, but i was too focused on just making the switch. Good info!
Old 01-17-2011, 06:11 PM
tdi_hatch's Avatar
anytime
Old 01-18-2011, 09:38 AM
TDP
TDP's Avatar
The stock flywheel really isn't that heavy. It's only 23lbs. The pressure plate with my clutch (Diamond Clutch) is 2-3lbs heavier than stock & Monster appears to be the same way. Hence the reason for using a lightweight flywheel. It makes up for a heavier pressure plate and then some.
Any one of the Diamond Clutch complete kits (Stage 1, 2, or 3) comes out to 43lbs total.
If you were to use a stock flywheel or a heavier billet flywheel, it would be heavier than stock.
Old 01-18-2011, 01:07 PM
tdi_hatch's Avatar
just going by what mine weighed and now what the monster weighs
Not sure why mine weighed 48-49 lbs wither way i saved my self 2-3 lbs
Quick Reply: monster clutch weight info!
