Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
need help guys/warranty is almost up
Old 01-17-2011, 10:38 PM
626cts-v's Avatar
Default need help guys/warranty is almost up
whats up guys i am going to take my caddy to the dealer for what might be my last time being able to use the warranty. i could do up to three things on this trip my mechanic says. my radiator just went out so there is number 1. here are some things ive recently had done.
1. ac comp
2.motor mounts
3.tranny mount
4.axels
5. rear end(twice)
what else guys??????? thanks
Old 01-17-2011, 10:41 PM
itsslow98's Avatar
My clutch pedal stuck at the drag strip once so i used this tSB to have the clutch and pressure plate replaced under warranty.
05-07-31-001 TSB Clutch Pedal Does Not Return to Up Position During Shifts at High Engine RPMs (Inspect Date Code and Replace Clutch Kit)
Old 01-18-2011, 01:41 AM
xxrillixx's Avatar
3 items? 50k mile warranty or GMPP?
Old 01-18-2011, 06:02 AM
.Houdini.'s Avatar
Yeah I'm not following the 3 item thing either...
Old 01-18-2011, 05:39 PM
626cts-v's Avatar
gmpp.....
Old 01-18-2011, 07:07 PM
xxrillixx's Avatar
You can get more then 3 things done at a time. Ive had 5-6 things done at a time. Just thought it was odd the mechanic limited it to 3. As the warranty agreement has no limitation per visit for cost or number of items that can be fixed in one visit.
Unless you have something different then I do. The GMPP, w/ $100 deductable.
Quick Reply: need help guys/warranty is almost up
