****many lsx parts for sale****
LS1TECH Sponsor
07 LS7 ECM Locked by MTI $50+shipping
Reground LS7/2/3 Cam 242/251 116. With a 1.8 rocker the lift is 663/700. With a 1.7 the lift is 630/661. This is a very similar cam: https://ls1tech.com/forums/dynamomet...m-cam-lgs.html
You should be able to get very similar drivability with this cam. $300 Shipped
Ported LQ9 317 heads w/valves. Milled .020, valve job. $725 Shipped. The heads are fully hand ported and bowl blended. We can add Comp 918 springs for an additional $180 or used LS2 yellows for $25. We ran these heads on a turbo Silverado and they picked up a ton of power over the stk heads and dramatically cut down on the spooling time.
These heads flow int 270CFM @ .600 lift and 188exh
Ported LS1 241 heads w/valves. $500 Shipped. We can do milling -.030 and a valve job for $200. and or add Comp 918 springs for an additional $180 or used LS2 yellows for $25.
These heads are fully hand ported and bowl blended. These heads are a killer bang for the dollar head that will beat a mild ported 243 head in price and performance.
These heads flow 265@ 600 and 190 exh
NEW Tial MVR 44mm Wastegate $359. silver SHIPPED
NEW Tial Q Blow off Valve $229. silver SHIPPED
NEW Stock LS7 1.8 Rocker Arms
NEW Stock LS3 1.7 Rocker Arms for offset LS3 heads
Will beat market value for these just gotta move them and make space for other stuff.
Stock used LS2 Yellow Springs 30k miles $50+shipping
We Also have STK LS7 cams for $100 shipped.
used STK LS7 exh systems exh manifolds, cats midpipe $400 plus shipping good for about 20 RWHP on a C5 or C6. Will need to reduce to mufflers.
We have MANY hi-Flow injectors for LS1 42-50Lbers $300 72lbers for LS2/3/7 $325 shipped and 96lbers $500 shipped. We can provide all the data to tune these injectors.
We have many other Turbo parts and fuel system components for sale both new and used. LS7 fuel pump, KB boostapump, FAST Fuel rails, Boost and FP guages, intercooler, Alkycontrol.com methanol kit, PTE 76/75 Billet turbo, Greddy profec-B boost controller, etc etc. Just ask via PM.
WE have intake manifolds L76/ LS2/LS3/ LS7 all ported heavily for sale outright $400-$500. We have fuel rails and injectors to make a complete manifold package add $135.
Thank you for looking
Jeremy Formato
Jeremy Formato
LS1TECH Sponsor
OK many new parts to add:
Used 500mi LS7 rocker set $200
Used 09 supercharged CTS-V cam and springs $150 shipped
Used ZR1 injectors $175 shipped
NEW bosch 47lb injectors $250 shipped
LS2/3/7 ported intakes for sale Stg1-2 outright($450-525) or core ($300-375)
Used LS7 radiator $225 shipped has tranny cooler in it
Used LS7 oil cooler and adapter with hoses $350 shipped
used LS7 cam (SINGLE BOLT with timing gear) $150 shipped will work on any LS2/3
Stk LS7 shifter with base that attaches to TQ tube $150
Stk 2011 grand sport fuel pump $50 shipped
