Fuel pressure prob.
Fuel pressure prob.
I got 2001 trans am and i put a fuel pressure tester on the shrecider valve..correct my spellin sorry..and its only showin 10 psi.. Is this a fuel pump issue? I mean the car starts and dies after 10 secs.
LS1TECH Sponsor
If it builds pressure, I would say it is not a wiring issue... the pump obviously works, but not well.
Pump could be bad, or a line or regulator in the tank has failed.
Does the pressure hold at 10psi, after you key on? If so it is not likely a leak.
Then I would consider it a pump or regulator problem.
I keep both in stock in interested.
