2002 TA Vats Disable with HP Tuiners??
I`m going to disable the Vats with HP tuners in my 2002 Transam, What also needs to be done after this is disabled in the PCM? I have already performed a Vats bypass with Resistors (Which Didnt Work). Your help is always greatly appreciated!
There are two parts to the anti theft. The key pellet needs to match for the starter relay to allow power to the solenoid to be able to crank. Then the bcm sends the fuel enable signal to the pcm to allow fuel via the injectors. If you bypassed with resistors and it cranks then once you disable VATS in the pcm you are good to go.
