Popping/back firing
Popping/back firing
So i drove my car for the first time today.. Has a nasty pop that sounds like its coming from one cyl.. Its kinda random though.. New opti and wires.. Mods are as follows..
mods are as follows..
new shortblock with arp rodbolts new bearings gaskets rings etc..
stage 3 ported heads
cc306 cam
1.6 rr
arp headbolts
new opti
csr elec. wp
new wires..
cc306 cam
1.6 rr
arp headbolts
new opti
csr elec. wp
new wires..
cc306 cam
1.6 rr
arp headbolts
new opti
csr elec. wp
new wires..
cc306 cam
1.6 rr
arp headbolts
new opti
csr elec. wp
new wires..
I am assuming you are tuned for the above mods?
RR's adjusted correctly?
SES light on?
GM brand opti?
Check for arching wires or wires touching the headers.
Hi,
i agree with above post. Check wires/coil packs/sparkplugs. If you had coil packs off/ may have out of order/check wiring diagram-color code for proper sequence.vacuum test is easy checks for leaks/valves/timing/etc.
Have a blessed day........jim
This opti has idle time on it.. and is brand new.. its a chandler.. I went through the test on shbox's website and its functioning correctly.. Im thinking its the plugs.. I should get around to pulling them tonight..
http://www.streetfire.net/video/97-t...or_814291.htm#
Not really.. i installed the cam with the motor on the stand.. Dot to dot.. rotated the motor over 3 times and checked the placement of the dots each time and it was dead on.. This isn't my first build..
So i replaced all the plugs and it got better for aabout 5 min.. NO backfiring.. but now its back.. All my plugs looked like the plug on the right.. EXCEPT no. 8.. It looked clean but was coated in fuel.. It seems like the issue gets worse after it gets warm as well.. Im thinking ICM right now.. I already have a new set of wires on the way and im gonna go get the coil and icm tested today.. LMK if anyone else can think of anything.. I'm assuming that #8 isnt firing and that its shorting on a header..
wasn't trying to say you would make such a simple mistake but when someone wants other people to help diagnose a car over the internet, you have to assume all possible scenarios until information proves otherwise.
as for the current condition, if only a single cylinder is having a firing problem that only occurs after running for a while I would rule out ICM and Coil personally.
are the injectors new on the car? I'd do a leak test on them either way (lift fuel rail, put key in on position and look for fuel drip)
also I would check for a vacuum leak around the #8 intake port.
