Noob Question - Removing PCM
I'm sending my PCM to get tuned by pcmforless. Just wondering what there is to it. Just a couple of screws or bolts? I've screwed up to much on this car this winter so far, not about ready for another problem.
2 10mm bolts on top and then pull up and out. There is not much slack in the wires but enough to pull out. 4 wiring harnesses plug in to bottom each a different color that is also marked on bottom on pcm so you cant get them wrong on reassembly. Remove red clips first, then gently remove 4 wiring plugs and you are done. very easy.
