timing curve, carburator?
Old 01-27-2011, 03:50 PM
bugy's Avatar
Question timing curve, carburator?
Wanna know what would be the proper timing curve for a LQ9 6.0L Ls1 engine carburated using MSD ingnition 6010, rod, pistons, crank stock, manifold dual intake, perf headers, compression ratio:11:1, heads casting 243,
cam: 236/242 duration, LS:113. I'm 1500 meters up to the sea level, and also the proper carb for this??? It's on a chevy colorado
Old 01-28-2011, 07:16 AM
moehorsepower's Avatar
Of course this is not exact but a ball park, all engines are different. try either 8-12 and or up to 12-16 degrees at idle, usually you would want all of your timing in (Say 36*) in by 2800-3000 RPM's..
Old 01-30-2011, 01:05 PM
LS1MCSS's Avatar
You'll get a lot more answers if you post this in the carburated section.
Quick Reply: timing curve, carburator?
