where will this 383 build put me?
Old 01-28-2011, 10:01 PM
little_chewy_69's Avatar
Default where will this 383 build put me?
okay guys im getting pretty pumped about this but be perfectly honest what i should be putting down for numbers
Build:
Factory MAFs Descreened
Fast 90/90
TSP 383 stroker kit 11.25:1
PRC 5.3L stage 2.5 heads worked "Flow chart attached below"
MS4 cam 111 degree LSA
Kooks 1 3/4" LTs
3" electric cutouts
Yank SS3600 in A4
stock rearend 2.73's "probably won't last very long"
http://s1130.photobucket.com/albums/...=flowchart.jpg
http://s1130.photobucket.com/albums/...artnumbers.jpg
Old 01-28-2011, 11:33 PM
180ls1's Avatar
did you already buy the kit? If you did it should be fun, if not and you have more budget i would look into building a 408 to see what the price difference is vs gains.
You also might want to ditch that MAF and go SD as that will be a restriction on your intake side unless you can pony up a few more dollars and get a bigger one. If not it wint hold you back too much.
Old 01-29-2011, 01:58 PM
david vericker's Avatar
Build:
Fast 90/90
Kooks 1 3/4" LTs
3" electric cutouts
Yank SS3600 in A4
I put down 482/441 on Livernois Motorsports DynoJet. Running a ported 78mm FAST - 1 3/4" LT's - Futral (Cam Motion) 241/245 .645 .633 114+4 GMPP 243 CNC 61cc heads with 11.3:1 SCR and a ton of other mods.
Old 01-29-2011, 02:04 PM
slowride's Avatar
Depends if you can lock the converter on the dyno or not? In a m6 car I would think 480-510whp is possible depending in the cutouts are open and you take the time to set every little thing up right. Ported fast, tight quench, etc, etc. It's all in the details.
Old 01-29-2011, 02:13 PM
00 black ss's Avatar
im trying to figure out what power mine will make to. im m6 and have a way larger cam. going to end up picking up a 92/92 and upgrade my maf and lid. just wont know bc im on stock 243s. hoping it will be around 500 at the wheels tho
Old 01-29-2011, 02:24 PM
yes all the parts ordered or previously owned by me. so this will be how it goes together for now. I might buy 100MM Mafs later but not right now. So i was thinking between 430 and 460 tops don't think you can make 500 with these heads.
