58x or 24x reluctor wheel
Is there a way to take off the OEM reluctor wheel and install it to your aftermarket crank?
If not what are some companies that make aftermarket kits in order for the stock crank position sensor to work?
You either send it to a competent machine shop and get a 24x reluctor wheel on or you can use this from LPE : http://www.lingenfelter.com/mm5/merc...Category_Code=
