Squealing A/C Compressor
I've had this high pitch squealing/squeaking coming from one of the pulleys and today i decided to investigate. I narrowed it down to one of the three, ac/drive pulleys. Pulled both idler and tensioner off, and repacked them with grease, but still same squeak. So.... It's defiantly the A/c compressor which I've been having problems with for 2 yrs. (clutch constantly kicks in and off at idle and blows hot until i get rpms up) So do I need a new clutch and compressor or is there a way to repack the pulley bearings if it's even that....,
I believe I have a noisy a/c pulley bearing that needs replaced. Found this writeup if anyone has the same problem.
https://ls1tech.com/forums/general-m...-clutch-2.html
