piston and ring kit.
Old 01-31-2011, 06:58 PM
TravisMcGill2000's Avatar
Default piston and ring kit.
Well i broke timing chain in my new motor. Well a couple valves hit the piston and took decent chunk out . They are forged speed pro's.. So i gona pull the motor back out and change the pistons. Well the ? is wat piston and ring kit do yall recomend. I wana go with something lighter and stronger than speed pro. I plan on spraying a 200-250 shot. Its a 355 with 21* heads and scat i beam rods.. Thanks guys
Old 01-31-2011, 07:16 PM
AChotrod's Avatar
Hellfire rings
Old 01-31-2011, 09:47 PM
RamAir95TA's Avatar
What kind of timing chain did you use, and why did it break?
Old 02-01-2011, 03:59 PM
It was a autozone brand timing set. I think thats why is broke. It being a el cheapo.
Quick Reply: piston and ring kit.
