i know this question may seem dumb but....
but i know our bolt patterns are 5 by 4.75 also known as 5 by 120.65..... but will 5 by 120 mm wheels fit a fourth gen camaro? i found some badass wheels on wheelstudio.com and their pattern is 5 by 120 mm......offset is not an issue because they will be custom built with an offset of my choice thanks. also they will be 18's all the way around so i can put the ctvs brembos up front.
They will fit. Some people say you will need a hub centric rings or something like that(dont remember exactly) but others have said they didnt use anything and everything was all good. Im sure someone will pitch in alittle more info. Just try an search and you should be able to find something.
