Need spring recommendations for this cam
I was recommended a 222/222 .597/.597 110LSA +0 cam from Patrick G for my setup. He recommended PAC 1518 beehives or TEA Gold Duals springs. I was just wondering if there are any other equivalent springs from different manufactures that would work with this cam. Its a stock LS1 engine with stock heads. Thanks.
I'm running Patriot gold on a 222/222 NZ Cam, but listen to Patrick, he's the cam guru here. You really didn't even need to start this thread.
those springs that were recommended are on the money,
beehives are great especially n/a,and up to 7000rpm
and price is great,we us these on our n/a engines....zero problems...period
cheers dave
cheers dave
PAC 1518s would do the trick. If you wanted the security of having a double spring you could go with Lunati dual golds for about $220. I have run both and have had good luck.
