Cam bearing question??
I am doing a LQ9 swap and I am installing a Custom EPS cam. The motor is out of an 03 escaldae and had 70K miles on it....
When I pulled the cam there is copper showing on the cam bearings...However I have read on here that this is VERY common and they guys with Brand new motors and motor with less than 10k miles are seeing the same thing...
I have also heard that they Line Hone the cam bearings from the factory (another reason for the copper) and if you change them you risk spinning them...
So what is the verdict? Do I let it ride and is it normal on these motors or do I change them and if I do do I risk spinning them?
Also I have heard that after 00 the rod bolts were much better...I am going to spinning the motor to 6800 at the absolute highest should I go Katech or leave them alone?
Thanks
Matt
Thanks
Matt
wow, that interesting ! which bearings are showing copper and in which spots? im putting together a 50k 2000 ls1 short block and i saw where the rearmost bearing on mine was showing that and only at the bottom,i was already getting prepared to buy all new bearings cause i thought that was bad news when a bearing is worn like that
Like I said I seen where a couple sponsors had posted in old threads that they seen the same copper color on brand new crate motors....
