Fog Lights Question
Fog Lights Question
i have my 99' z28 and my foglights arent coming on but the dash indicator is lighting up. is it when you burn one bulb in these lamps that they both go out??? i havent dug into it much just puzzled.
if one was out the other would still light up. sounds like both crapped out on you or they arent getting power. try a voltmeter on the bulb plug when switched on. if they both went now is a good time to get some hids
Could be the fog relay went bad.
If you need bulbs do yourself a favor and get 886 bulbs. They are 50W instead of the stupid 27W or 37W bulbs you normally would have, and they actually make a difference. The housings are all metal and glass so the extra heat isn't an issue.
