which pcm?
Old 02-07-2011, 06:36 PM
70shortwide's Avatar
Default which pcm?
i bought a ls6 out of a 05 cts-v and need to know which pcm would be best to use with it? im new to ls thing so wanna make sure i get the right one. its going in a 70 chevy shortwide.
Old 02-08-2011, 07:06 AM
SOMSS's Avatar
You will need a 05 Vette pcm if you are going to go with fuel injection. Will cost you about $100!
Old 02-08-2011, 07:45 AM
scatillac's Avatar
It depends on the type of throttle actuation you'll be using as some (2003+) do not have the IAC drivers.
I believe that an '05 OEM V (Serv. #12589462, Hdw. #12589161) ecm has the drivers and will work for either application. They are also found pretty common usage in 2003+ Yukons, Suburbans, and Savanna/Express vans.
Another Savanna/Express ecm, Serv. #12576106, Hdw. #12570558 also has the IAC drivers for a cable throttle.
The very common 12200411 ecm will also work in both applications.
There's a thread on here somewhere about converting dbw harnesses to cable configuration that has all the info you'll need.
Old 02-08-2011, 12:46 PM
I should prolly specify that its just a short block. So can i use a 99 up camaro pcm and use that type of intake?
Old 02-08-2011, 07:28 PM
S10xGN's Avatar
Not to jack, but has anyone by chance compiled a list of which PCMs are compatible with which harnesses and what PCMs have what functions?
Quick Reply: which pcm?
