a4 to m6 swap
a4 to m6 swap
so i been playing with the idea of the swap for a while now, just have A few questions.
car is a 1998 z28 a4 camaro with a built 4l65e swap.
found a t56 im picking up
i plan on picking up a 1998 m6 harness with ecu.
i have all parts for the 6 speed swap.
anyone have any instructions for this?
im workin on the same swap right now. You can do the swap without getting a new harness and pcm. its alot of work to switch one out. Do some research before you start so you dont get pissed and give up on the swap.
When I had my 99 Trans Am like 8 years ago, I went from A4 to M6, then a year later went back to an A4. I swapped the pcm/harness each time & no problems
yup, read through the stickies and you can knock it out pretty easily. Everything that i needed to know for mine was all in that sticky.
I took my time and went away for school so it took me about a month or so to do it, but i had a daily driver so i took my time. If i needed to do it quick, i could knock it out in a weekend.
