Dood001
02-09-2011, 08:22 PM
Okay, today i noticed water leaking on my car and it smelled like radiator fluid. My car was parked lately for the past 3 months because i was driving my other car, but i made sure my car was turned on every week. On the floor were three different spots... It only leaks when the car is on, obviously, i think? I'm not sure if it CAN leak while off? As of now i found two different leak spots:
On this first picture, on 1 (one) you are able to see radiator fluid. I am not sure if it leaked from above and was dripping or its leaking from the flush. On 2 (two) is where i found some water like (or it can be radiator fluid) on the trims.
http://i52.tinypic.com/jjtvdi.jpg
On this picture is where i saw radiator fluid dripping along the ridges
http://i54.tinypic.com/264l3jp.jpg
Here are the three different spots just to let you see where the leaks are come from. The spot from the far right, the bigger one, is right direct below number 1 from the first picture.
http://i56.tinypic.com/sqkprp.jpg
