Tranny Pan Question
Tranny Pan Question
I'm looking at getting a transmission pan with a plug in it for easy filling and draining. Almost every pan I see has raised bolt holes. This normally would not be a problem except for the fact that my automatic transmission gear selector thing has a bracket that bolts to the pan with two longer bolts. Will this still bolt up correctly with the raised bolt holes or will I need a pan with a flat flange? If you are wondering it's one of the cheapy 700R4 pans on Ebay. The transmission is a 4l60e in a 2k Z28 Camaro.
