Is there a factory 4 bolt dbc tb?
Old 02-13-2011, 05:16 PM
crankstart's Avatar
I've been searching the classifieds for a 4 bolt dbc throttle body for my ls2 intake and it's been hopeless. Can you only get that combination in aftermarket?
anyone?
Old 04-25-2011, 10:43 PM
Dracer35's Avatar
I am having the same problem. I have a ls2 intake setup but I want a dbc throttle body for my conversion setup in a different vehical. So far the only two I see available are:
Scoggin Dickey 90mm LS2 DBC TB: $359.99
http://sdparts.com/details/scoggin-d...-center/sd90mm
Nick Williams 92mm LS2 DBC TB: $377.99
http://speed-eng.com/store/nick-will...dy-p-9435.html
Either way, thats more than I want to pay for a throttle body. There are ebay knock offs but ive read that they are not machined correctly and the IAC valve does not fit.
I was thinking about trying to find A LS2 dbw tb and removing the electronic actuator and installing a normal cable setup from a ls1 tb but who know if that would work or not.
Hope this helps.
Quick Reply: Is there a factory 4 bolt dbc tb?
