LY6 runs but wont idle help please
the motor is in a 79 C10, and the harness was redone by speartech. I got running first about 2 weeks ago, it is straight headers and i did not have the O2 sensers hooked up, it would crank and isle just fine. Now i was gonna take it for the first test drive so I hooked up the O2's and just kind of rigged them with wire ties so they would stay just inside the opening of the headers. And now it will not idle. It pulses for a minute and dies, also the check engine light is flashing, Any ideas? do i just need to get the exhaust done and the sensors mounted correctly maybe?
Also when you start your car at first, the ECM runs open loop, not referencing the O2's, then after a period of idle, goes to closed loop referencing the O2's.....
Bozz
ok thanks, one more thing i forgot to ask about...during the first test drive i was going down the road and the thing just went crazy, no pedal response and barely idling. After some head scratching i noticed that somehow the positive post of my battery was touching the metal housing of my trans ecu, obviously it was shorting to ground and causing the problem. I have since relocated my ecu so that it wont happen again, but do you think i could have screwed the ecu?
The reason why I know this, because it happened to me before, and we spent 2 weeks chasing our tails trying to figure out WTF it was...
Bozz
ok, so i figured out that i fried my trans ECU, so what does it mean if the pedal does not respond sometimes? before i figured out that it was fried sometimes the pedal would not respond and i had to cut the truck off and back on and it would work fine. Could it just be the computer doing it?
