Need Ideas. Electrical issues
Just had the car completely apart, new internal stuff. Now im stuck with codes dealing with electrical components. Throwing 2 codes with the following readings: Cam position sensor, Clutch position sensor, RPM guage never comes up, and traction control says its stuck on. Might be a bad ground or connection, but no clue where to start looking. Thought maybe someone else has encountered the same issue. Car runs and drives with no problem. Thanks
