Gm 5.3 into 86 Buick regal
Old 02-16-2011, 08:01 AM
kenjbeaty's Avatar
Default Gm 5.3 into 86 Buick regal
Bought a 5.3 for 200 dollars and looking to install turbo. The motor is a 2005 model,( Is this a Gen IV?) and if so I would like to go to a cable throttle body. I bought a ls1 intake and fuel rails. Do I need to get a camaro wiring harness. Are all of the sensors i.e knock , IAC and everything the same. any info would help. Kenneth
Old 02-16-2011, 01:19 PM
GNCLONE's Avatar
Default Regal swap
Wish I could answer your questions - probably can't. I think the newer LS motors had variable valve timing.
I have an '87 Regal and am starting an LS swap too.
Old 02-16-2011, 04:31 PM
69cutlassrkt's Avatar
Its a GenIII. I kept the DBW on mine, I like it.
Old 02-16-2011, 04:45 PM
robbyredneck's Avatar
i love my dbw, it sure made cruise hook up easy it feels different but civil. you may need the fbody fead also. but i would consider keeping all of the truck stuff on it (if it's allready there) and buying a truck harness, pcm, tac and pedal. the cable only "seems" easier
Old 02-16-2011, 05:00 PM
deuce4935's Avatar
What are the casting numbers on the heads and the block? You shouldnt buy a harness without knowing for sure if its a gen3 or gen4 due to the 24x reluctor(gen3) and 58x reluctor(gen4). The 2001 Cadi Escalade motors were gen3's with 24x reluctors and were dbw, the 97-04 Vettes were the same. Dbc installs easier but to use the car intake you will need an idler relocation bracket for the truck engine.
Old 02-16-2011, 10:08 PM
BLWN1's Avatar
I have a turbo and headers ready for a Gbody in the classifieds...
Quick Reply: Gm 5.3 into 86 Buick regal
