Manual Transmission - Transmission Advise
Krepitus
02-17-2011, 09:27 AM
I have the 6 peed manual in my 1998 Z28. The sychronizers for 3rd and 5th were going out, so I took it too th e local tranny shop. The said it needed a rebuild and the clutch replaced. After several increases in the cost I ended up paying $2600.00. Before it went in the shop I usually started off in 2nd gear for typical city driving, because first was so low. Now, starting in second lugs the motor way down, and overall performance is suffering. before the "repair" I could mash the peddle in second while going 30 mph and rip the tires loose. That doesn't happen now.
Also, shifting to Reverse takes quite a bit of muscle, so much so that my wife can't do it.
Did they screw it up?
Edit: They put a LUK clutch in. Was that a good choice?
KevinR
02-17-2011, 09:30 AM
Wrong section. Try the manual transmission section.
RPM WS6
02-17-2011, 09:35 AM
Moved to manual trans section.
Jeremy@RPMTransmissions
02-17-2011, 11:38 AM
If it is taking that much effort to get the shifter into reverse, they may have left the reverse lock out solenoid unhooked. As for the car driving differently after the rebuild I find that very strange. The only think that might cause that is if something was binding up in the transmission or a bearing has failed. The LUK clutch is a cheap stock replacement clutch that will last about half as long as the factory. Back in higschool we would say "You will be LUKY if it lasts the summer".
I hate hearing stories about guys getting taken advantage of by local shops. For the price you paid them, you could have had one of our built Level 5 transmissions. Or one of our Level 4 transmissions and a SPEC clutch....
Keep us posted and provide any info you think might help us help you diagnose it.
Krepitus
02-17-2011, 05:28 PM
Thanks, I wish I would Have checked thesse forums first.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
