2nd corvette accesories??
I'm doing a ls swap in a 73 firebird with a formula hood. My plan is to a budget engine swap buying good parts for a foundation after the fitment,fuel, wiring etc is worked out (and I save up enough money)
So basically I'm going to do a 5.3 or 6.0 I know I need an Fbody pan, but I kind of like the accessories of the Corvette, I remember my Z06 being easier to work on than the Fbodies I'd owned.
So what do I need from the vette, alternator bracket, tensioner, crank pulley, alternator and waterpump? Any down falls to this and more important does it fit under a stock Firebird hood? I've seen one on here with vette accessories but no details on the rest of the swap.
I'm thinking Dynatech swap headers and car shop plates (although I need to confirm steering linkage is not an issue with that setup...
Any real word experience on this, suggestions on my plan?
All I have right now is a 05 GTO T56 so I'm starting from scratch and would like to do it right the first time!
Bobby
Bobby
I have the vette set up for my LQ4, it'll be going into my 80 Z28 come spring time. From what I have heard there are no issues swapping it in.
You'll want the Balancer, pulley's, tensioner, alternator, Power steering pump, water pump, basically the whole front drive assembly.
These are some of the part numbers I used:
GTO LS2 2005 PARTS
92211821 Alternator Mitsubishi 140A
12563327 Alternator Front Bracket
92175482 A/C Compressor AC Delco 1521469
12557335 A/C Pulley AC Delco 154670
06581307 A/C Pulley Clutch Assy AC Delco 154962
Dorman 594127 Crank Pulley
88932746 Serpentine Belt 78" AC Delco 6K775
Gates K060775 Serpentine Belt 78"
Dayco 5060775 Serpentine Belt 77.5"
88932543 A/C Belt 43.75" AC Delco 4K430
Gates K040430 A/C Belt 43.75"
Dayco 5040430 A/C Belt 43"
89049313 Serpentine Belt Tensioner Assy. Grooved Plastic Pulley 70x17x25. = Gates 38195 =Dayco 89338
89049314 A/C Belt Tensioner Assy. Smooth Backside Pulley 65x17x20. =Gates 38196 =Dayco 89339
89032092 Idler Pulley. Smooth Backside 76x17x30.5 = Gates 38041
88909589 Idler Pulley. Grooved Plastic. AC Delco 38008 70x17x25 = Gates 38008
Part -GM # -GM Cost
Fuel rail O-ring kit -89017587 -$28.95
Fuel Rail -12572174
Fuel Injectors(8) -89017586
Fuel Injector Retainer (8) -24503227 -$13.04
MAF -25318411
Starter -92169668 -$280.22
Water Pump -89018034 -$236.33
Power Steering Pump -92161580 -$259.74
Power Steering Reservoir -92176477 -$47.09
Power Steering Bracket -92066673 -$26.60
Power Steering Bkt Bolt -92138830 -$5.76
Power Steering Pulley -92066499 -$45.02
AC Compressor -92175482 -$451.61
Compressor Bracket -92066950 -$48.89
Compressor Bkt Bolts(6) -11515771 -$19.14
Compressor Bkt Bolts(2) -92138526 -$22.70
AC Lower Belt Tensioner -12560345 -$59.83
AC Belt -4K430
Drive Belt -6K785
Pulley, Top Idler -12557335 -$31.73
Drive Belt Tensioner -92111701 -$37.64
Drive Belt Tensioner Bolt -92138257 -$8.50
Drive Belt Idler Pulley -12563326 -$36.68
MAP -16212460 -$62.50
Fuel Rail Cover, right -92066954
Fuel Rail Cover, left -92066955
LS1 F-body Oil Pan set -12558762 -$199.79
Oil Pan pick-up tube -12558251 -$33.91
Oil Dipstick -12551581 -$9.99
Dipstick Tube -12551577 -$7.04
Oil Deflector -12558253 -$17.83
LS1 Alternator bracket -12563327 -$15.66
LS1 Alternator bracket -12556915 -$11.53
The F-body LS1 alternator brackets are listed because the GTO alternator is stupid expensive!
Upper Rad. Hose -10271554 -$30.48
Lower Rad. Hose -10271555 -$18.41
Steam Tube -12556452 -$10.55
GTO LS2 2005 PARTS
Part -GM # -GM Cost
Fuel Rail -12572174
MAF -25318411
AC Belt -4K430
Drive Belt -6K785
