06 gto master or z28 master for t56?
i read that the gto mster is undersized it also sticks and and causes missed shifts at high rpm. is this true? if so, should i go to the camaro style with the slanted flange. it seems that there isnt a master relocation bracket for my 79 camaro available for the gto master either if there is let me know
did u adapt it to your exhisting clutch pedal or is the pedal aftermarket? i wouldnt mind using it cause i already have the gto one. the bracket that u fabbed is it completely flat and bolts to the booster flange?
ok so the z28 style has an internal spring and the gto doesnt. in oerder to use the z28 i would need a special fitting on the trans and that means pulling the trans. and the there is a special connection on the gto master wierd any help would help
