checking bearings
checking bearings
I have a new to me but unknown mileage 96 lt1 and i am planning on checking the bearings as well as installing a bunch of new parts.
what i need to know is how to check the bearings, do i just unbolt the main caps and check the bearings then reinstall and re torque? what is the torque required for the main caps
and with the rod bearings, I will do those after the mains and just manually turn the motor over and do the same things as with the mains, correct?
should i use assembly lube? motor has sat for 6+ weeks
what scares me is that i dont have the proper tools to check bearing tolerances, and those tools are definately out of my budget even though i would love to have them, I know that you can used plasticgauge but i know that isnt asaccurate as the proper tools.
