RPM 505s 18x9 on all 4 corners?
Old 02-23-2011, 08:31 PM
CLA803's Avatar
Default RPM 505s 18x9 on all 4 corners?
Like the title says, is anyone running the 18x9s on all 4 corners? will the 38mm offset be ok on the front? not sure if i want to drop to an 8 in the front.
Old 02-23-2011, 08:46 PM
carlos64030's Avatar
38mm offset is perfect and is the recommended offset.
Old 02-23-2011, 09:04 PM
lemons12's Avatar
With only having a 275 out back you won't mind having an 8 up front.
Old 02-23-2011, 09:16 PM
oh1ws6's Avatar
True, it makes the rear look way wider than it really is haha
Old 02-23-2011, 09:51 PM
CLA803's Avatar
the reason for the 9s up front in when the rear tires wear out i was thinking of widening the rear wheels to give it a staggered look later on down the road.
