What side is a Bank 1 and Bank 2????????????
Old 02-15-2004, 02:40 PM
Herb C's Avatar
Default What side is a Bank 1 and Bank 2????????????
For the sake of putting in my oxygen sensors if I need them, on a dual exhaust system, what side is Bank 1, and what side is Bank 2 on?
1996 Ford Taurus 32-valve dual exhaust (V-6)
Old 02-15-2004, 02:45 PM
2xLS1's Avatar
On a LS1, bank 1 is the drivers side, but I've also heard it can be the side that has Cyl #1 on it. Cyl #1 is on the drivers side on a LS1. Don't know about Ford.
Old 02-15-2004, 05:47 PM
Restricted User
EFILive's Avatar
Under the OBDII standard, bank 1 is *always* defined as the bank that contains cylinder #1 - for all vehicles.
Note: That means for inline engines, that only have one bank, that bank is bank 1.
As 2xLS1 said, (for the LS1) bank 1 is the drivers side in the US, but is the passenger side in other countries like Australia and New Zealand. That is why (in SAE J2012 - Diagnostic Trouble Codes) the SAE defines bank 1 based on cylinder #1 and not "driver/passenger" side.
So to know which side it is on your Ford, you'll need to know which side has cylinder #1.
Regards
Paul
Old 02-15-2004, 10:02 PM
wrencher
wrencher's Avatar
Thats it exactly.
On your SHO bank 1 is the rear cylinders 1,2,& 3.
Bank 2 is the front towards radiator cyl. # 4,5, & 6.
Ya ford is screwy the have low bank/hi bank where as most everyone else has odd & even.
Quick Reply: What side is a Bank 1 and Bank 2????????????
