Fuel Pressure Drop at WOT ?
hi guys
i have big Problems in fuel pressure, every think its ok in idle and med rpm
bout in high rpm ( wot ) 5200 and up 6700 drop fuel 65 to 40 psi i will check the wiring and i change the fuel pump selver aeromotive with a controller same Problems drop fuel .
aeromotive (-12 inlet and -10 outlet)
-10 fuel pump to y
-8 y to aeromotive fuel rails
aeromotive Regulator 1:1 ( the Regulator Used not new )
Thanks for the inputs in advance
-10 fuel pump to y
