What size injectors???
What size injectors would be best for my application? I have a 2000 Z28 that has Pacesetter LT's, TD's, 4.10's, and a MS4 cam that I will be installing along with a set of Ported 243 Heads. I plan to add a 100 wet shot to it also. Just curious as to what would be best for my setup. Any help is greatly appreciated.
thanks for the quick response! I was thinking maybe a 42lb. but didn't know if that would be overkill for the setup when I was not spraying. Thanks for the advice as that is what I will go with.
http://www.corvetteinjectors.com/sho...?productid=324
