Ls3 intake in a f-body throttle cable question
Old 03-07-2011, 07:44 AM
bowman2005's Avatar
Default Ls3 intake in a f-body throttle cable question
I need a throttle cable bracket that does not bolt to the back of the throttle body like the one from scoggin dickey because I have a plate kit that I am running. Any other companies making the conversion brackets?
Old 03-07-2011, 07:49 AM
same o'j's Avatar
Default brakect
i think you will need this :
http://speed-eng.com/store/slp-throt...ke-p-8910.html
thanks
Old 03-07-2011, 03:28 PM
Irish350's Avatar
that looks to be the same as the SDPC design, more or less..
maybe lokar?
i feel your pain, i had an SDPC w the wrong bolt holes so i had to swap them; not sure whatll happen when the nitrous comes
Old 03-07-2011, 04:07 PM
Quick99TransAm's Avatar
Default Brackret
If you have the stock ls1 cable bracket I can show you how to make it work and it looks clean and not rigged.
Old 03-07-2011, 04:09 PM
Irish350's Avatar
go on
Old 03-07-2011, 10:28 PM
Rick Speed's Avatar
Yes Please tell us more!
Old 03-08-2011, 09:47 AM
Default Bracket
Here are some pics all you need to buy is a little piece of thin angle from home depot or lowes which cost like 3 bucks.Just have to weld in two spots it looks clean.Also Google the slp cable bracket and compare it to mine.If you need anything else just let me know
Attached Thumbnails Ls3 intake in a f-body throttle cable question-gedc0212.jpg   Ls3 intake in a f-body throttle cable question-gedc0213.jpg   Ls3 intake in a f-body throttle cable question-gedc0214.jpg
Old 03-08-2011, 08:41 PM
Rick Speed's Avatar
Nice job man. they have a similar design for $50. this way cheaper.
Old 03-08-2011, 09:05 PM
Irish350's Avatar
meh.. wish i wasnt on a timeline or i wouldnt have already bought one from slp
its already half way across the us
Old 03-08-2011, 11:15 PM
bowman2005's Avatar
Okay thats pretty cool there man. thanks guys
Old 03-16-2011, 11:38 PM
bowman2005's Avatar
now I can not find a ls1 throttle cable bracket to make this piece!
Old 03-17-2011, 11:13 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
We do have this billet option too:
But it's more money. $89
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-04-2011, 11:34 AM
JimMueller's Avatar
I bought the SDPC unit last summer which bolts to the back of the TB and wasn't happy with the pedal height and cruise cable slack, so they gave me a good deal on a NW 92mm because they didn't have the problem on NW92's. So I replaced the BlueMax90 that Vengeance had sold me to go with my prior motor's Fast92 intake. I also wasn't happy that I needed to hack on the acoustic cover to make it work.
I recently bought the SDPC billet bracket from another forum member just in case it would allow me to use an unhacked acoustic cover. I installed it this past weekend and I went back to the TB mounted version. The billet placed the throttle pedal too close to the floor, unhid part of the hacked cover but still wouldn't fit without the hack, and didn't have the unintended benefit of the TB bracket which kinda prevented the LS1 MAP sensor from falling out. In fact, one could probably modify the TB bracket to help keep the LS1 MAP sensor in place.
I'd like to buy a pre-fabbed bracket which could give adjustable cable slack, be lined up perfectly behind the TB cam so it doesn't rub against the edge of the cam, and fit correctly with the acoustic cover.
The following users liked this post:
777Shock777 (06-06-2021)
Old 04-04-2011, 11:59 AM
the_merv's Avatar
That looks pretty good..
I have the Holley 90mm Throttle Body with a Holley Bracket on my L76 Intake.
Old 04-06-2011, 03:09 PM
JimMueller's Avatar
Photo and/or part number of the Holley bracket?
Old 04-06-2011, 09:05 PM
the_merv's Avatar
I cant find the Part Number..just call Holley and ask them what the Bracket is for the 90mm LS1 4-Bolt Throttle Body..that is what I did.
Old 12-30-2011, 05:12 AM
chuckd71's Avatar
I haven't used it before, but would jb weld be strong enough to hold a bracket like that together? Would be nice to spend $10 and make my own bracket but I don't want to worry about it snapping apart.
Old 03-05-2012, 06:24 PM
BanditDave's Avatar
Not sure you found a solution to this yet but I am about to make myself one...be glad to throw one together for you as well if you have the LS1 cable bracket.
Dave
Old 09-20-2012, 11:19 AM
red281gt's Avatar
Resurrecting this need help with diy. I don't want to spend $90.On a bracket
Old 09-20-2012, 07:09 PM
the_merv's Avatar
I think mine was $25..
Quick Reply: Ls3 intake in a f-body throttle cable question
