Injectors?
Old 03-07-2011, 09:48 PM
94fixerTA's Avatar
Default Injectors?
Wondering which injectors y'all think I should go with.
My setup: 383, cc306: (230/244 .544/.576 112lsa) w/ 1.6RR's, gasket matched intake, mildly potted heads, LT's with TD's, 58mm tb, and CAI. May go with a 75 or 100 shot. Also don't have it tuned yet. Still putting it together.
Old 03-07-2011, 09:57 PM
myltwon's Avatar
if it's a dry shot 36-42lb, if it's a wet shot 30lb
as for brand Ford Injectors have a great rep, Accel injectors suck ***
Old 03-07-2011, 10:01 PM
BigD383lt1's Avatar
I'm running 36# injectors... with a 383 with similar mods without the shot but think you should be more then fine!
Old 03-08-2011, 06:43 PM
94fixerTA's Avatar
It won't be a track only or a DD. Just something to play with when I want to drive it. So the 36# would be better?
Old 03-08-2011, 07:23 PM
ss.slp.ls1's Avatar
I'd use an injector calculator to calculate what injector flow rate you need to stay under 80% duty cycle.
Old 03-09-2011, 06:57 AM
DAVE00's Avatar
If spraying as you say then go with 36# to be safe, if not then SVO30#'s will be fine.
Quick Reply: Injectors?
