Stock Fuel Pump
Stock Fuel Pump
I'm building an injected 496 stroker using an Edelbrock Pro Flo XT.
I'll be running it with an 0411 ECM.
I'm about to start the fuel tank and was wondering about what fuel pump/sender I should use.
I see there are all kinds of aftermarket pumps.
Are they used because the stock fuel pumps support only a few HP or are the aftermarket more reliable?
I probably won't be going higher than 550 HP , 650 FT/LBS torque.
