5.3, howell harness and a tbi truck
i got a couple questions guys, first off i have a 5.3 4l60 combo with a howell standalone harness with comp and im wanting to put it into a 88 chevy one ton it currently has a 454 th400 but i guess my question is will everything on the truck work if i use the howell harness?, i know the gauges probably wont so im looking for a crafty veteran for some help thanks guys
yoru will ahve better luck at www.ls1truck.com, this is what those guys live for. I did this in a 1990 but my guages are all aftermarket. the guys at the above site can solve all the issues you are talking about.
LS1Tech Sponsor
Just an FYI we are working on an adapter harness to integrate LSX/Vortec engines into the C/K Pickups. PM me for details. This would allow retention of the gages and other electrical items while eliminating the TBI harness.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
You can get some sensor adapters and use the trucks original sensors and wires to operate the gauges, just be sure not to cut the wiring. The temp sensor from the 454 will be installed at the rear of the passenger side head, oil pressure sender will go to the rear of engine, the voltage will come from back of alt, fuel will remain the same you will only need to change the pump in the tank and the run the hotwire for the pump to the relay of the Howell harness.
LS1Tech Sponsor
We agree and will be detailing our first C/K swap in a thread on LS1Tech.com. Should start in the next few weeks.
__________________
Ebay Store
Ebay Store
LS1Tech Sponsor
Will keep everyone updated. Just received a good lead on a 6.0 instead of a 5.3 for the swap. We will be getting this going soon.
__________________
Ebay Store
Ebay Store
Thanks
LS1Tech Sponsor
Right now focus is on the TBI swaps only. Once we develop the interface, we will look into the 'old' vortec platforms and see what is applicable.
__________________
Ebay Store
Ebay Store
Call Howell directly and talk to their tech department. You can ask for Troy? who helped me immensely with my LS1/4l60E setup with a Howell harness and reflashed ECU. I bought the stuff used and he still answered all of my questions and offered to reflash my ECU for me pretty cheap. Their wiring harness will operate all of the gauges; hell I made it twice as hard on myself and reverse engineered it to work with the idiot lights!
Check out http://www.hotrodlane.cc/PDFFILES/Lisa%20Tahoe.pdf, Vortec is even simpler than the tbi.
LS1Tech Sponsor
Adapter harness in development (had a very busy spring and didnt get to swapping the motor in the truck we are developing the harness from). Will be starting a thread on this in the next few weeks as components get removed and replaced. Once completed we will move forward with prototyping and testing, then production.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
My 6.0 liter GTO stand alone Harness and ECM was from them. Troy is a real real nice guy to work with.
It really boils down to what you want though as I wanted to retain my stock gauges for a stock look.
So essentially, other than the tach output, that they changed in the ECU to allow my stock 8 cyl tach to work, nothing was needed from and ECU\wiring standpoint for the other gauges.
However, at my request they also added cruise wiring to use my stock cruise stalk on the steering column with the LS2 Drive by wire.
Jon
PSI
Jon
PSI
Hmm. Interesting. I'll be starting my 6.0 swap into my 92 k1500 soon. I wasn't sure if i was going to retain stock guages, go aftermarket, or my third option is swap to 97 style dash..
