ls2 cam sprocket.. which one?
Hi I am doing a ls9 cam swap in my 4.8. I know I need the front timing cover with the sensor on it and the ls2 sprocket. It turns out I bought a ls2 timing chain kit before having intentions of doing this cam swap. The timing chain kit came with this sprocket:
But when I look at some conversion kits, they include this cam sprocket:
Which one should I use?! The first one I already have so I wouldn't have to spend the money on a new one. But if it won't with the front cam sensor then I guess I'm stuck with buying the other style one.
Lemme know if you guys know if I can use the first one.
Thanks
Thanks
