fuel leak!
fuel leak!
I keep on getting nasty fuel leaks on the top of the injectors where they go into the fuel rails. At first they would leak only when my second fuel pump kicks on(under boost). Now they leak whenever I start the car. I already replace the top o-rings and they still leak. This is only happening on the passenger side. I have 60lbs injectors with aftermarket fuel rails. Do I need bigger o-rings?
they are nasty performance rails. The passenger side injectors lean a little forward so that the front end of the rail with the 8-an plug is right infront of the bracket that holds the throttle cable. The drivers side injectors lean back, so the passenger side rail leans more forward than the drivers side. I already lubed the o-rings to make shure they go all the way in. The o-rings are not vissible when they are tighten down. They just keep on getting pushed out when I start the car.
