What did I do wrong?
Old 03-18-2011, 05:39 PM
HuskerZ's Avatar
Default What did I do wrong?
I changed my plugs and wires several weeks ago and I am still not sure what is up. Long story short, I used ngk tr5ix plugs gapped @ .040-.042 and my second set of wires are a standard set from oreillys. I had trouble with the plugs vibrating lose already, but I went back through and re-set each one. Now car runs ok and I have been driving, but just doesn't seem to have as much power and at times I swear it's going to start idling too low. Could the gap be too narrow, did I still not get them tight enough (I doubt), or anything else. I am really pissed that I didn't IMPROVE the cars performance.
Old 03-18-2011, 06:30 PM
RARON455's Avatar
I run the TR6s at .O35 wwhat kind of mods on your car, why did you go with that plug
Old 03-18-2011, 07:09 PM
HuskerZ's Avatar
I only have a catback and air lid. All else bone stock. I searched on here for a while and found the ngks to be favorite and thought the iridium would be a good upgrade. I also found that the gap people use varied greatly, and even oreillys had a few different specs.
Old 03-18-2011, 08:04 PM
13lu91rS's Avatar
too cold of plug for your application? drop down to tr55 or just tr5's and see if that helps.
Old 03-18-2011, 09:31 PM
The Mighty Texan's Avatar
I run Tr55 gapped .05 common for a bolt on car cant go wrong
Old 03-18-2011, 11:21 PM
garygnu's Avatar
test your old wires and maybe reinstall if they flow better then your new wires.
Old 03-19-2011, 11:52 AM
samson_420's Avatar
Maybe,
The plugs seem fine, just a NGK iridium.
