Will this get me there?
Actually, you could run 12's now with those nittos. You should be able to at least cut low 1.9's if not 1.8's. Smoke them in waterbox for 8 seconds, about 17psi. Dump clutch at 3k, if she bogs launch 3400 next time, if she spins 2700. Sometime as high as 4300!!! Once you cut low sixties, your time will drop dramatically. But with the asp and cutout, combined with good weather and low sixties, you will see 12's all day long. hope this helps.
went from 13.5 in heat of summer to 12.5 with nothing more than winter, nittos, and about 20 passes at the track.
banks
banks
Originally Posted by n2o
Smoke them in waterbox???????????? If you still have the stock master cyl. that may be your problem.
