wierd shifting problem
I have trouble shifting into gears when i get on it after ive already gone thru 2 gears (say i start from 1st and it wont go into 3rd) (or if i start from 2nd it wont go into 4th) unless i pump the clutch once or twice. Im not much of a tranny guy so i have no idea where to start the fix. I put a cam in it about 1800 miles ago and it started doing it after the swap but not immediately after. Any ideas what the problem is? Thanks..
Do a search here . Not sure of the specific drill size but you remove the feed line and open the end at the master. Unless you are very lucky, you should remove the master, disassemble , drill , clean, re-assemble , bench bleed( a key step) ane re-install. Then do a system vac bleed.
