car turns over but doesn't start..
I can hear the fuel pump come on, it turns over fine but doesn't start. It did this last time I had it out but it eventually started. but I just tried it tonight about 10 times and it wouldn't start.
What are the possibles for this problem?
I did a search and read something about the fuel relay. Is that just a fuse?
If you think your getting fuel...then I would check to see if the spark plugs are getting spark. Then go from there.
Just remember to check the obvious things first before you go and tear everything apart.
Administrator
Yep, do what dood said. Check your fuel filter (Fuel). Check your intake track (filter, lid, MAF, TB, IAT, etc). Check your plugs & wires (Spark).
Just look for the basics then report back. We can dig if need be.
Where's wrencher on this one?
