What plug does this go to?
Old 03-22-2011, 06:17 PM
ricky levins's Avatar
Default What plug does this go to?
l have a 99 trans am ls1, the main wiring harness that runs into the coil packs on the drivers side of the motor. Well there is a plug that comes out of the same loom that isn't hooked to anything, it had two wires if I remember correctly red with a black stripe and just red? Maybe? What does this go to if it goes to anything?
Old 03-22-2011, 08:58 PM
joshp14's Avatar
2 wire connectors I can think of on that side are either the AIR solenoid or evap purge solenoid. I believe the purge solenoid is a red connector body though. You have a picture?
Old 03-22-2011, 09:23 PM
Nah no picture, I mean it comes right out of the loom like an inch or so ahead of the main plug for the drivers side coil packs. I beleive it was a grey plug?
Old 03-23-2011, 11:45 AM
sjsingle1's Avatar
think that is the AIR plug
